1 minute ago, breezy2984 said:
I am using amd ryzen 5 7600x 4.7 ghz 6-core processor with MSI MAG X670E Tomahawk, Corsair Vengeance RGB 32GB (2 x 16GB) DDR5 6400MHz. I am wondering if I can use 6400Mhz for ram with the amd ryzen 5 760x cpu or should I keep it at lower mhz speeds?
You can put it higher and after if your system take a performance hit you can lower it back.
https://linustechtips.com/topic/1609373-ram-speed/#findComment-16709235
I would keep it at 6000Mhz so you are sure you are running in 1:1 mode.
I am going to link you an answer from @RONOTHAN##
https://linustechtips.com/topic/1609373-ram-speed/#findComment-16709240
6400C32 is usable but unless if the price difference is signficiant, 6000C30 will be better on paper and in reality.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1609373-ram-speed/#findComment-16709450
