Budget (including currency): £1100
Country: UK
Games, programs or workloads that it will be used for: Game Development (low poly) and gaming (some AAA)
Other details Parts listed below. I am wondering whether this build is good for my budget, or if there is a few upgrades that can be improved/changed like making it cheaper but having the same performance
https://linustechtips.com/topic/1608931-build-help/
Country: UK
for the ram you will want speeds of 6000 and a cl of  30
https://linustechtips.com/topic/1608931-build-help/#findComment-16706023
4 minutes ago, x_lukeex said:
What would you recommend for those.
any kits will do just don't buy overpriced kits or ones with lots of bad reviews. brand wise I have used both teamgroup and g.skill, and have had no issues.
https://linustechtips.com/topic/1608931-build-help/#findComment-16706032
How tight is your budget?
https://uk.pcpartpicker.com/list/JMsLYd
You also want 2 sticks
current PC:
PC configs I used before:
https://linustechtips.com/topic/1608931-build-help/#findComment-16706042
