8 minutes ago, Ksit said:
Will fera 5 black be enought for amd ryzen 7 5700x?
the peerless assassin 120 se will do better, well still not cost a lot.
https://linustechtips.com/topic/1608290-help-with-cooling/#findComment-16701801
What are your options? For gaming only it could be decent choice.
How much for similar cooler from Thermalright, ID-COOLING?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1608290-help-with-cooling/#findComment-16701802
9 minutes ago, Sawa Takahashi said:
The 5700X is a 65W tdp CPU. Any decent cooler (including the AMD included stock cooler) is enough to keep is at an acceptable temperature.
I will just go with fera 5 because spartan 5 is really bad for me. I am getting 77c in peak while just rendering world in minecraft. (I builded pc today) I am also doing undervolting rn because I hope it will lower it as well
https://linustechtips.com/topic/1608290-help-with-cooling/#findComment-16701849
