Hey! I'm getting into music and higher quality video production and am looking for a user friendly audio interface and have looked at the Focusrite Scarlett Solo 4th gen, and the Universal Audio Volt 1. Would anyone happen to know which is better or have any other recommendations around the price point? Any help would be greatly appreciated! Also I'm not sure if its important but I've also been looking at the Audio-Technica AT2020 to pair with it.
https://linustechtips.com/topic/1608115-looking-for-help-with-an-audio-interface/
Generally speaking, you won't find a huge difference in audio quality between different interfaces. The biggest things are having enough inputs for whatever you're recording, phantom power (if you need it; and you do if you're getting an AT2020), and what fits your budget. Between those two, go with which ever one you like aesthetically or functionally (the knobs/switches/etc). What kind of music and/or videos are you making? Because there might be better interface/microphone setups depending on the type of content you're making that will be more multi-purpose. If you're getting into music production/studio recording, you're better off going with a bigger mixer with USB interface instead of a dedicated interface just for your mic.
