Hey guys, im looking to upgrade my PC but im not sure what to Upgrade other than the Graphics, i want to be able to play the latest games on Max settings and get at least 60FPS(BF3, Crysis 3, Far Cry 3, and others...). And also i will be using a lot of CPU intensive Programs such as CATIA, Adobe... and others.
Specs -
CPU - i7 930 @ Stock Speeds
Cooler - Noctua NH-D14
Mobo - Gigabyte X58A-UD3R
Ram - Corsair XMS 3 6GB 1333Hz
Graphics - ATI Radeon 5770
PSU - Corsair HX 750 v2
Case - HAF 932
https://linustechtips.com/topic/1608-upgrading-pc-need-help/
Do you feel restricted by your current CPU? If so, upgrade your Motherboard and CPU > Ivy Bridge ( or wait for IBE ). Do you feel like your graphics card is restricting you, are you getting low frames at the moment which makes your experience worse? If so, upgrade your GFX card. What's your budget aswell? :)
https://linustechtips.com/topic/1608-upgrading-pc-need-help/#findComment-22074
That CPU is epic, so leave that but overclock it. But I would suggest an aesthetic upgrade, such as upgrading the case to maybe a corsair 900D (when it comes out) or a TJ07 or TJ11.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/1608-upgrading-pc-need-help/#findComment-22083
Hmm, tbh speed wise im not too bothered, i mean the i7 930 is still good i guess, i can just overclock it using software (IM A NOOB) whenever i feel i need the extra power :D. Graphics wise i get around 40FPS in BF3 at Medium settings in 1080P, so i guess ill change that. my Budget is £700. Any Graphics card u would suggest? I was looking into getting two GTX 670 FTW's and beasting it out :D, but also would my PSU be powerful enough ?
https://linustechtips.com/topic/1608-upgrading-pc-need-help/#findComment-22086
Sorry for double post' date=' but i want to change to case to something a little bit more silent, like a Fractal R4, if the Mobo will fit lol :D[/quote']
Your motherboard will be able to fit in the R4, plus it's a nice case :D
https://linustechtips.com/topic/1608-upgrading-pc-need-help/#findComment-22110
