Ram help!
Go to solution Solved by rhodestech,
On paper, the current RAM you have is faster than the Kingston RAM.
This is my setup : http://pcpartpicker.com/user/LordCreeper/saved/t2VD4D
What If I change the r9 series ram to this one :
http://www.amazon.com/Kingston-KHX16C9B1RK2-8X-DDR3-1600-240-Pin/dp/B008XQEQT4/ref=sr_1_15?ie=UTF8&qid=1401722567&sr=8-15&keywords=8gb+ram
The Pc wont have more lag or wont be slower with this one, Right?
- Lord
https://linustechtips.com/topic/160780-ram-help/
Social Links: LTT Forum    Website    Instagram    Twitter    YouTube    LinkedIn    Steam
The Build
CPU Intel i7 4770k 4.4ghz Motherboard Asus Sabertooth Z87 RAM 34gb (4 x 8gb) Corsair Vengeance 1600mhz GPU Evga GTX780 Classified Case Lian Li O11 Dynamic Storage Samsung 840 256gb SSD PSU Corsair HX750 Display Achieva Shimian QH300-IPSMS 1600p Cooling Corsair H100i Keyboard Corsair K90 Mouse Corsair M65 Sound 3.1 Surround Sound Fans 2x Corsair SP120 PWM, 3x Corsair AF140 Q.E, and 1x Corsair AF120 Q.E.
https://linustechtips.com/topic/160780-ram-help/#findComment-2140224
Will it change the In-game fps if I change the ram?
System RAM speed does not make that much of a difference, unless you are running integrated graphics. How come you want to go for slower RAM anyway?
The Build
https://linustechtips.com/topic/160780-ram-help/#findComment-2140242
