XLR cable confusion
Solved by Omon_Ra,
The 'M' designation is for male (it has the pins, not the sockets); the 'F' on the TA3F is for female (sockets, not pins). On the microphone side, it uses a mini XLR connection (the TA3 designation), so a standard XLR cable will not work should that one ever fail. Just use the included cable and everything will be fine.
toxic_worper ·
Posted in New Builds and Planning4 -
2
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3
