Hello,
Yesterdays someone suggested me to try out Parsec as a remote connection for my macbook to home pc solution. it works pretty well so far, the only problem is side buttons on mym ouse doesnt work. For them to work on my macbook I use SaneSideButtons  "app", but after I connect to parsec buttons stop working. any way to make them work someone maybe know solution?
https://linustechtips.com/topic/1607441-parsec-macos-problem/
