Aura Sync Issue
Go to solution Solved by alex75871,
I managed to fix the issue. The update center had updates for the UWP App and Core Services; after installing those, updates became available for devices and components. Then, after a restart and searching for updates again, the 5080 Astral showed up as an updatable component!image.thumb.png.6c12228a6dcabbb6e7999e1e1284a478.png
I have 3 components in my system that support ASUS Aura Sync:
ASUS X870-F GAMING WIFI motherboard
ASUS Astral 5080 GPU
G.SKILL Trident Z5 NEO RGB 64GB DDR5 RAM
But I cannot get the GPU to sync with my motherboard and RAM. The GPU shows up as an Addressable LED Strip but does not sync with the other two components. What am I doing wrong? I don't want to return my GPU because of a lighting issue if it can be avoided.
https://linustechtips.com/topic/1607328-aura-sync-issue/
https://linustechtips.com/topic/1607328-aura-sync-issue/#findComment-16695269
