Hey there guys, if any of you have ever used the Wattpad app on phones, they are great, the page scrolling is nice, and everything is organised very well. I've tried a few book readers on android, and currently using Moon+ Reader. However, I don't really like the layout and page scrolling. Does anyone have an app which has nice page scrolling & layout like Wattpad ?
https://linustechtips.com/topic/160702-best-e-readers-for-android/
i'm using Moon+ Reader Pro, and i am very happy with it.
what don't you like about it?
edit: you have many options to change how scrolling etc. works.
| CPU: intel i7 3820 OC to 4GHZ with H100i cooling | Case: Enthoo Evolv ATX glass | Mobo: Asus P9X79 Socket-2011 | RAM: Corsair Vengeance DDR3 1600 MHz 16GB | GPU: MSI GTX 1070 Gaming X
| PSU: Silver power 750w plus silver | SSD: OCZ Agility 3, 240GB / Toshiba 500GB | Monitors: Dell U2713HM, Acer Predator 27" | Headset: Sennheiser HD650| Soundcard: Xonar Essence STX
The page shifting, you should try the Wattpad one. It's waaay nicer!
https://play.google.com/store/apps/details?id=wp.wattpad
there is wattpad for android, wouldn't that solve it for you?
Moon+ Reader is a good choice for eBook readers and it's the one I'm currently using.
https://play.google.com/store/apps/details?id=com.flyersoft.moonreader
I use to use Aldiko Book Reader, but after I updated my Android version to 4.4 I switched to Moon+ Reader because Aldiko didn't have a compatible version at the time. I think they might now but I just can't be bothered switching back to Aldiko even though I found it to be slightly more usable.
https://play.google.com/store/apps/details?id=com.aldiko.android
