Hey there. When I go to plug in another USB device on my new pc (NZXT prebuilt), it either doesn’t work, or something else doesn’t work.
I’m going to add all my specs, then the peripherals I use…
H Series H9 Elite Edition ATX Mid Tower Chassis
MSI Z790 GAMING PLUS WIFI (DDR5)
Intel i9-14900KF Tray
Team T-Force Delta RGB 64GB (2x32GB) DDR5 6000
(FF3D516G6000HC38ABKT)
WD Blue SN580 1TB NVMe SSD (WDS10013B0E) x2
Gigabyte RTX 4090 Windforce V2 24G (GV-N4090WF3V2-24GD)
Kraken Elite 360 - 360mm Alo liquid cooler w/ Display and Radiator Fans
(Black)
C Series ATX 1000 Watt 80 Plus Gold Version 1 Analog Full-modular
Power Supply, US Power Cord
9. WIN 11 HOME ADVANCED OLC 0A3 (KUK-00003)
Here are the USB peripherals I use.
1st gen Elgato Stream deck
Elgato Stream Deck Pedala
Elgato Wave XLR
HyperX Full size keyboard
Logitech G PRO Superlight. (newest model)
Logitech Brio 410
Logitech PRO X2 LIGHTSPEED
It seems like I can only have 5-6 running at a time. Any thoughts on what I can do to solve this issue? I have updated all drivers already.
https://linustechtips.com/topic/1606390-usb-issues/
Is it a particular port failing each time? Are you adding to the rear IO or the front, and which fails?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/1606390-usb-issues/#findComment-16689231
Not a specific port. It’s just the rear io with a warning that I have maxed out system resources. Any help is greatly appreciated!
https://linustechtips.com/topic/1606390-usb-issues/#findComment-16689280
USB ports have a maximum power output and maybe you are exceeding that limit somehow. But it is probably Windows tripping instead of a real hardware limitation.
Do you have a USB hub you can use ? Try using the hub to plug many devices into the same port. Still getting the issue ? If you have a powered hub, if you plug the power adapter, does it make a difference ?
Hope that helps.
https://linustechtips.com/topic/1606390-usb-issues/#findComment-16689621
