Budget (including currency): flexible, nothing too absurd, just a mid-range PC, probably $600 to 1500 AUD range, if lower value works just as well without much trade offs then that can work as well, and vice versa for higher value
Country: Australia
Games, programs or workloads that it will be used for: Genshin Impact, and other gacha games (mostly)
Other details
- Only needs the tower, already have peripherals etc
- Already have Casing (Corsair 3000D Airflow), and Storage (NVME and 2.5 HDD from laptop)
- Needs a PC to run games like Genshin, is iGPU/APU good enough to run it? If yes then GPU can be skip for now. (it's fine to run 1080p 60 at low for now)
- If using iGPU/APU, will probably add a GPU down the line (not included in budget if not needed at the moment) to run heavier games, so PSU would preferably be around 550-650W range (enough for mid-range GPU yes?)
Essentially, I need CPU (and cooler if no stock), motherboard, RAM, and PSU recommendations, I think that's all I'll need? And a potential GPU candidate. (Prefer Nvidia because of the softwares used)
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/
https://www.amazon.com.au/s?k=m.2+heatsink&crid=W31NFTDNG240&sprefix=m.2+he%2Caps%2C238&ref=nb_sb_ss_ts-doa-p_1_6
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($155.00 @ Computer Alliance)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  ($29.00 @ MSY Technology)
Motherboard: *Gigabyte B760M GAMING PLUS WIFI DDR4 Micro ATX LGA1700 Motherboard  ($179.00 @ Computer Alliance)
Memory: *G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($74.66 @ JW Computers)
Video Card: *Zotac GAMING Twin Edge GeForce RTX 3060 12GB 12 GB Video Card  ($429.00 @ PCCaseGear)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($69.00 @ MSY Technology)
Total: $935.66
Generated by PCPartPicker 2025-03-23 03:16 AEDT+1100
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688147
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 3060 12GB 12 GB Video Card  ($469.00 @ Computer Alliance)
Total: $975.66
Generated by PCPartPicker 2025-03-23 01:41 AEDT+1100
Do I have to be locked into a GPU right now?
Does the PSU have (as much as I hate it) the new power plug Nvidia uses?
The intel CPU oxidation only affects 13th and 14th gen, right? I haven't followed tech in a while so I am not quite sure exactly what's going on.
Is AM5 platform is too costly for enter? Was thinking APU would suffice for now.
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688152
https://www.msi.com/Power-Supply/MAG-A750GL-PCIE5
PCI-E 5.0 (16 PIN): 1 (450W)
CPU: *AMD Ryzen 5 8500G 4.1 GHz 6-Core Processor  ($226.00 @ MSY Technology)
Motherboard: *MSI B650M GAMING WIFI Micro ATX AM5 Motherboard  ($169.00 @ BPC Technology)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($144.00 @ MSY Technology)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.00 @ Computer Alliance)
Total: $678.00
Generated by PCPartPicker 2025-03-23 02:03 AEDT+1100
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688163
The APU/iGPU for games even for gacha games will depend on the game itself sadly
WuWa for example on a 8600G (best option if you want to get into AM5 without a GPU for the time being) CAN run it at 60 fps at medium to low settings (preferably a mix of both with where it needs it)
Genshin on low tho on it will be like this
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688164
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($328.66 @ JW Computers)
CPU Cooler: *ID-COOLING FROZN A610 BLACK 78.25 CFM CPU Cooler  ($49.00 @ PLE Computers)
Power Supply: *MSI MAG A750BN PCIE5 750 W 80+ Bronze Certified ATX Power Supply  ($99.00 @ Centre Com)
Total: $1218.66
Generated by PCPartPicker 2025-03-23 02:25 AEDT+1100
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688171
icic, yea i forgot wuwa existed because the user the PC is intended for doesnt play wuwa, so other than wuwa i think most gacha games are pretty chill in term of requirements.
Albeit the gameplay looks smooth, should be fine with Genshin then
Total: $678.00
Total: $1218.66
the G and non G is stronger and weaker iGPU? or the non-G just has no iGPU at all?
as for GPU, 3060 still recommended? icic...
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688173
The non G cpu's are better for gaming. The 3060 12GB will give you decent fps at 1080P.
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688176
WuWa is the game that ran fine
Genshin was at 30 to 40 FPS on 1080p LOW
Quite frankly I'd rather you go am4 or 12th gen 12400f with a dedicated GPU like the 3060 12gb like @Why_Me says or the iGPU will not give satisfactory results even at 1080p low depending on the game
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688182
oh dang, didnt expect genshin to run worse.
aight then, i appreciate the input, thank you!
https://linustechtips.com/topic/1606230-au-need-a-basic-pc/#findComment-16688188
