linux Using gpu built in lcd in linux
Solved by yamin1kgf,
On 3/23/2025 at 10:49 PM, Haswellx86 said:This is Linux man. We don't game. We don't have fancy PCs. We have an old Toshiba laptop compiling the kernel for the 8th time on the TTY.
I am obviously joking. But god have mercy if you want to setup RGB. All of them have proprietary Windows software. OpenRGB or other software might work, but only if your manufacturer obeys the standard so that it can be detected.
i made it work though (RGB only )
it was not easy at all
sorry for insulting the great haswellx86 may your soul be high in the kernals land .
oh i only did the RGB without finding how to do the lcd so far no luck with putting femboys in my gpu lcd
thanks to all
