need help with mounted gpu compatibility
Go to solution Solved by jaslion,
You'll need a different case. There is barely enough space for an aio to fit when using that adapter which also doesn't really fit out of the box in the case.
Budget (including currency): 1500$ US
Country: USA
Games, programs or workloads that it will be used for: Fortnite, Marvel rivals, cyberpunk
I'm planning to build a microatx PC in a Fractal Pop Mini Air, and I want to mount a Yeston Sakura RX 7800XT with a coolermaster vertical mount. However, I also plan to use a Thermalright Peerless Assassin 120 SE and I'm afraid that it won't fit when vertically mounted. Would I be able to mount the GPU vertically with that? Thanks so much!
https://linustechtips.com/topic/1605342-need-help-with-mounted-gpu-compatibility/
10 minutes ago, thiinan said:
would it be worth it to buy a Corsair 2500x? The only reason I am going for the pop mini air is for the included fans
https://www.montechpc.com/air-903-max
PCPartPicker Part List
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($79.90 @ Amazon)
Total: $79.90
Generated by PCPartPicker 2025-03-14 21:44 EDT-0400
