Budget (including currency): €1500-1700
Country: Belgium
Games, programs or workloads that it will be used for: RDR 2, Tom Clancy's Ghost Recon Breakpoint, Hell Let Loose, Alan Wake 2, ...
Other details
I am planning to build my first ever PC for 1440p gaming and some general usage.
Below you can find the part list. Are there any remarks on this?
Many thanks!
https://pcpartpicker.com/list/jyPyLc
https://linustechtips.com/topic/1605165-first-pc-build/
Country: Belgium
Other details
Many thanks!
Hey, welcome to the Forum.
This is a great build and there isn't much if anything I would change.
I would maybe pick the Thermalright Peerless Assassin 120 SE ARGB CPU Cooler over the Dark Rock 2.
The PA 120 SE is better, costs less and has some RGB to match that Lian Li case 🙂
Due to the PA 120 SE having two fans I changed the RAM to a lower profile RAM so it doesn't interfere with the CPU Coolers front fan.
Be aware that the B650 will need a BIOS update for the 9600x to work but this is not a problem as this board has the Q-Flash feature.
This means you can update the BIOS without any components installed except the 8pin CPU power cable and the motherboard 24 pin 🙂
https://pcpartpicker.com/list/bWhDmC
https://linustechtips.com/topic/1605165-first-pc-build/#findComment-16681027
Country: Belgium
Other details
Many thanks!
Looks fine to me, but those prices are ouch.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1605165-first-pc-build/#findComment-16681028
Only thing I would likely change is your CPU to a 7600, 9600 is fairly pricey in comparison and has very little performance uplift.
https://linustechtips.com/topic/1605165-first-pc-build/#findComment-16681029
This board down below supports PCIe 5.0 for the graphics card as does the new AMD and Nvidia cards including the 9070 XT.
One more thing, you want a 120mm exhaust fan for that Lian Li 207.
https://be.pcpartpicker.com/product/68WfrH/arctic-p12-pwm-pst-563-cfm-120-mm-fan-acfan00120a
https://www.msi.com/Motherboard/PRO-B850-P-WIFI
https://www.techspot.com/review/2728-ryzen-7500f-vs-core-13400f/
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
PCPartPicker Part List
CPU: *AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€169.00 @ Azerty)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (€50.85 @ Megekko)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard  (€209.00 @ Azerty)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€99.90 @ Megekko)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  (€87.99 @ Amazon Belgium)
Power Supply: *Thermaltake Toughpower GT 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€99.93 @ Azerty)
Total: €716.67
Generated by PCPartPicker 2025-03-14 01:53 CET+0100
https://linustechtips.com/topic/1605165-first-pc-build/#findComment-16681461
