For some reason whenever i turn on my pc, there is a random chance that my case fans aswell as the liquid cooler will light up very dimmly it is completely inconsistent but usually after around 1-4 shutdowns and reboots of the pc, no matter what i do the fans stay turned off until i turn on and off the psu after which it works fine until it doesnt. I've been struggling with this problem for about 3 months. I dont think it's a faulty pin connector as it without fail always works fine after a psu restart, but then again I don't know much so any suggestions are welcome.
Specs:
https://pcpartpicker.com/list/FzJdJn
https://linustechtips.com/topic/1604722-weird-fan-argb-problem/
If the PC shuts down and reboots as well as the fans being dim, it’s probably a PSU issue. It’s not distributing the power correctly and giving the fans/pc incorrect power which is why it’s rebooting randomly.
MY PC:
Ryzen 9 3900X 12 Core PBO Enabled
ASUS RTX 4070 DUAL OC
Asus Prime x570 Pro Motherboard
Kingston Fury Beast 128GB RAM 4 Slots
Fractal Design Case
EVGA 80+ Gold 800W PSU
https://linustechtips.com/topic/1604722-weird-fan-argb-problem/#findComment-16677761
