GPU Hot Spot
Solved by Dedayog,
8 hours ago, Alix said:Been playing truck simulator and just turned on my hotspot information ( junction temperature ) on the Xfx AMD Radeon RX 7600 just wondering if 90 Celsius is normal or is it overheating?.
Also, I had an idea would stick in fans underneath the GPU will help this stays cool.
100% fine.
No need to check random temps unless you know what the info represents.
Just use your PC normally. they're all working just fine
