I bought an RX 6600 that gave me some problems, after talking about it here on the forum I decided that I'm going to buy an RTX 4060, I'm just in doubt between 2 models. One with 2 fans and the other with 3 fans, I leave the links below (I'm from Portugal, sorry for the English)
https://linustechtips.com/topic/1604023-need-some-recommendation/
RX 7600 XT is around 375 EUR -  385 EUR :
3 fans, 375 eur Gigabyte Radeon RX 7600 XT Gaming OC Placa gráfica de 16 GB, núcleo de 2810 MHz, 16 GB GDDR6
https://www.amazon.es/-/pt/dp/B0CSSZCZZP/
2 fans , 385 EUR ASUS Dual Radeon RX 7600 XT OC Edition 16GB GDDR6
  https://www.amazon.es/-/pt/dp/B086ZTKLXQ/
It has 16 GB of VRAM on board, so it would last longer than a 8 GB 4060 card, games are more and more vram hungry, and it's around 5% faster at 1080p, and around 10% better at 4K compared to 4060 :  https://www.techpowerup.com/review/sapphire-radeon-rx-7600-xt-pulse/32.html
 The card consumes 200 watts ...  debatable if you need a 3 fan card.
The problem is that I need on white (I have a white build)
Well... if color is more important than performance ...
Your only options on AMD's camp are more expensive, 7700 XT, 7800 XT
Placa gráfica Sapphire 11330-03-20G AMD Radeon RX 7800 XT 16 GB RAM : Amazon.es: Computadores
XFX Speedster QICK319 Radeon RX 7800XT Core (RX-78TQICKW9) : Amazon.es: Computadores
Sapphire Pure AMD Radeon™ RX 7700 XT Gaming OC 12 GB GDDR6 Dual HDMI/Dual DP : Amazon.es: Computadores
7800 XT is maybe 1-2% better than a RTX 4070 but comes with 16 GB VRAM...  around 5-6% better on average at 4k
7700 XT has 12 GB vram but it's still ok.
If you are looking for a good budget GPU. The Intel B580 might be a good option 😀.
The Asrock steel legend or the Sparkle Titan Luna OC is good for a white build.
CPU - Intel® Core™ i9-14900K
CPU Cooler - Arctic Liquid Freezer II 360 A-RGB
Motherboard -  Asus ROG Maximus Z790 Hero
RAM - G.skill Trident Z5 RGB (2x16GB) 6000Mhz cl30
Graphics Card - Sapphire Nitro+ Vapor-X RX7900XTX 24gb.
Gigabyte Aorus RTX 4070 Master 12 gb.
Power Supply - Corsair RM1000i
Storage - Lots of fast storage...
Case - Corsair Crystal 570X RGB Red Edition
Colour Theme - Red & Black
Operating System - Windows 11 Pro
Keyboard - HyperX Alloy FPS RGB
Mouse - Speedlink Decus Gaming Mouse Limited Edition (Black)
