My setup is
Intel i3 9100f
Corsair Vengeance LPX DDR4 32 GB (16x2 ) Dual Channel Ram
AsRock B365m HDV Motherboard
750W 30$ local PSU
sata m.2 SSD for os
LG 1080p 75Hz Display
I had built this PC with ASUS Cerberus Nvidia GeForce GTX 1050ti OC Edition  in 20210-2021 as my first build.
I am from third world country so gaming is a ultra luxury so i was content with running modern games at 20 fps and old/optimised  games at 40fps  but then IT STOPPED WORKING RANDOMLY , last year or so..
now i have no Graphic card.
i Absolutely cant upgrade my other components like CPU or PSU , i just want to replace a broken GPU due to broke reasons
My needs are : A GPU that isnt bottlenecked too much by i3 9100f and has only 1x8 pin PCIE power connector
my current shortlist is
or INTEL B580 for around 360$
help me with choosing.   ( NO good USED market in this country ),
https://linustechtips.com/topic/1603432-need-help-plan-a-gpu-upgrade/
18 minutes ago, DRKGMR-A said:
My setup is
Intel i3 9100f
750W 30$ local PSU
sata m.2 SSD for os
Ever considered buying a handheld instead?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
all of these gpus will be bottlenecked by that cpu so I would just get the cheapest one, the whiteish rx7600.
it is ok to have some cpu bottleneck anyway, all it really means is that you must understand that you will not see a good price to performance the further you go.
How is your country for import? What I would do in this situation is import a used card from Japan via proxy shipping service. there are risks to it but you can swing a gpu and cpu for the same price I think.
A GTX 1070 or 1070 ti is probably the best you can do before the bottleneck is noticeably bad enough. Unfortunately I don't have better advice to give other than buy the best your budget allows.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
3060Ti > 4060 > 7600
Intel discrete GPU is going to have unacceptable CPU bottleneck with your old i3
The AMD/Nvidia options will probably still be bottlenecked. The best workaround to this issue is GPU-based frame generation, so I would not recommend the 3060Ti because it lacks this feature.
For anyone who is going to bring up Lossless Scaling or similar aftermarket solutions, these all run on the CPU which is only going to worsen the bottleneck.
so ideally a 4060 or 7600
7 hours ago, McCarthy said:
I'd try to find a used 8 GB 1070. I find them on US ebay for 70 bucks. Will get you 30+ FPS. You could save the rest, and keep saving, for a bigger upgrade down the road.
bigger upgrade , u mean whole setup or just a higher gpu ?
The B580 is slightly slower than the 4060 with fewer features, but has 4GB extra of VRAM. My nephew is playing minecraft RTX on that and it works well.
At same cost personally i would get the B580 12GB, but MSRP cards pop out if you pay attention, at least in my market.
but my cpu is older than 10th gen intel so it wont be able use the rebar and other features hence have way less performance with b580
On 3/3/2025 at 9:18 AM, DRKGMR-A said:
6800 is 320$ (used) here
Might be ur best deal. oh it's way better than what's in ur screenshots. but hey if u dont buy it plz make nvda sales go up.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
