Building AM5
Solved by Millios,
40 series cards are scalped to high heaven most of the time and the 50 series is terrible value
I'd suggest looking for reasonably priced 40 series cards or better yet second hand or all together jumping ship to an AMD gpu as it is better value
From your marketplace I peep
9700x 4.5ish million
b650 eagle ax 6.783 million
ADATA XPG Lancer RGB DDR5 6000Mhz 32GB (2x16GB) CL30 - White 1.75 million
Montech xr 0.75 million
That will do and is about 13 to 14 million Rupiah
For an extra 5ish million you could also swap the 9700x to a 9800x3d which is the best all around gaming chip in the market
Only thing you could improve here? A cheaper 6000mhz cl30 kit if there is one and a case if you dont like the one I chose
