https://pcpartpicker.com/list/bgt62x
Cheaper and improved
Alternatively for some extra looks an NZXT H5 with some white fans but that is a bit of a price hike
Also everything in these (aka yours too) are in USD not CAD
in CAD its a little more like this
https://ca.pcpartpicker.com/list/jY99np
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664524
a white power supply is pointless because it will be covered anyway
also if you REALLY want a white motherboard https://ca.pcpartpicker.com/product/zFzhP6/asrock-b650-pro-rs-atx-am5-motherboard-b650-pro-rs
doesnt have wifi tho
First custom PC soon(-ish)!
Current part list:
Case: Corsair 4000D (✨WHITE✨)
GPU: Radeon RX 7900 XT
CPU: Ryzen 7 7700
CPU Cooler: Thermalright Peerless Assassin 120 (✨WHITE✨)
Mobo: ASRock B850 Pro RS
RAM: ADATA XPG Lancer Blade 2x16GB 6000MT/s CL30 (✨WHITE✨)
SSD: Lexar NM790 2TB
PSU: BQ Pure Power 12 M 850W
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664609
Just now, Millios said:
Why does that matter tho?
What significance does it hold?
maybe some people dont want an ethernet cable going across their house
ik that ideally you should have ethernet for online games anyway but i mention it just in case™
Current part list:
CPU: Ryzen 7 7700
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664653
You see there is this thing many to most houses have called ethernet sockets
In the router goes and boom ethernet access in every room via a neat little hole in the wall much like a power outlet
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664658
most =/= all, why not account for people who don't have them
Current part list:
CPU: Ryzen 7 7700
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664662
Why account for smt that you cant know exists or is asked for?Should doctors perscribe medicine that works for what they know a patient has or account for the 10s of diseases that the patient could potentially have and is not yet diagnosed with?
To circle back to the OG post to stay on topic casue this rant about houses having ethernet sockets and wifi being needless unless asked for has been going on for a while
OP originally chose a board without wifi, thus they most likely (almost certainly) have ethernet so wifi is a needless expense on top of the white tax so again it holds no value until OP says "Btw I want wifi"
https://linustechtips.com/topic/1602922-i-need-help/#findComment-16664671
