Multi purpose PC build
Go to solution Solved by Why_Me,
I stuck a RTX 4070 Ti Super 16GB in this build but the card you want is the new RTX 5070 Ti 16GB. Those cards should start showing up in better quantity within the next month. Add desired storage.
https://au.pcpartpicker.com/products/video-card/#c=589
RTX 5070 Ti 16GB
PCPartPicker Part List
CPU: *Intel Core Ultra 7 265 2.4 GHz 20-Core Processor  ($690.00 @ Skycomp Technology)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($59.00 @ Scorptec)
Motherboard: *MSI MAG B860 TOMAHAWK WIFI ATX LGA1851 Motherboard  ($370.00 @ Skycomp Technology)
Memory: *Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($289.00 @ MSY Technology)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($1509.00 @ I-Tech)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.00 @ Centre Com)
Total: $3165.00
Generated by PCPartPicker 2025-02-24 13:26 AEDT+1100
https://au.pcpartpicker.com/list/pCNJpK
Budget (4000 - 4100 AUD):
Country: AUSTRALIA
Expected use: machine leaning training, python, pyhtorch CNN models and such, 3d design, Solidworks, 4k video editing Davinchi resolve, gaming-sim racing with vr or 1440p Ultra wide 160hz.
Peripherals: 1440p Ultra wide and 1080p monitors, Sim racing and expected vr for Sim racing
Other details: coming from a Intel 11370h GTX 1650 laptop with 32 gigs of ram and 1.5 terabytes of storage (which is almost full), 1tb gen 4 nvme drive will be games drive in new build(using less than half for games). I'd the build to look nice because it will be on my desk next to me, because of this it should also be quiet under load. The 1tb nvme will be boot drive and the hard drive stroage for footage, I currently have 1.2 tb of footage. Any help for slight tweaks to complete redo is welcome.
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/
RTX 5070 Ti 16GB
Total: $3165.00
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/#findComment-16663943
1 minute ago, Why_Me said:
I stuck a RTX 4070 Ti 16GB in this build but the card you want is the new RTX 5070 Ti 16GB. Those cards should start showing up in better quantity within the next month. Add desired storage.
I would wait to see the reveal of the 9070 and 9070 xt for specs and price
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/#findComment-16663945
RTX 5070 Ti 16GB
Total: $3165.00
What's your reasoning for going Intel?
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/#findComment-16664238
11 hours ago, Why_Me said:
For 3D design I'd pay the Nvidia tax if my budget allowed.
is it really worth the cost though, all Nvidia is now is AI they even said at CES there 50 series wouldn't be possible without AI
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/#findComment-16664424
31 minutes ago, Arif787 said:
Would 7900xtx be a good option it's pricing is in low 4070 ti super range
if the 7900 xtx has better specs then the 9070/ 9070 xt then manly yes, but if the 9070 xt is just barely outperformed by the 7900 xtx and cheaper I would go with the 9070 xt so you have more money for other parts of your pc
https://linustechtips.com/topic/1602839-multi-purpose-pc-build/#findComment-16664460
