I was mainly wondering if the NZXT Kraken X60 would fit in my Phantom or if there was a better alternative for the same price or less.
Linkeys:
 http://www.newegg.com/Product/Product.aspx?Item=N82E16835146028
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146079&cm_re=nzxt_phantom_crafted-_-11-146-079-_-Product
https://linustechtips.com/topic/160271-help-with-the-kraken-cooling/
As for as I'm aware, the original phantom holds 2 200mm fans in the roof. I am unsure whether or not it can hold a 280mm rad. As for the AIO, the other option is the Corsair H110, which is basically the exact same thing as the X60. So go for whichever one is cheaper.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146111&cm_re=phantom_630-_-11-146-111-_-Product
Here's something to consider for a new case. It may be $20 more, but it's one amazing case.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
