Budget (including currency): 2700zł
Country: Poland
Games, programs or workloads that it will be used for: Gaming
Hi everyone, I would like to upgrade my pre-built PC, mainly my gpu and cpu and I know little on PC's but I have done some research and these parts should all cooperate smoothly together.
Right now I am running a Gigabyte GeForce GTX 1660 SUPER OC 6GB  with a Ryzen 5 5600x on a Gigabyte B550M DS3H motherboard and I was planning to upgrade to a Gigabyte GeForce RTX 4060 Ti 8GB with an AMD Ryzen 7 5700X3D, I would like some second thoughts on this 😅
https://linustechtips.com/topic/1602657-cpu-and-gpu-upgrade-help/
Dont get nvidia and especially the 4060 and any version of it
A 5700x3d is a great upgrade and pair that with the 7600xt for a GPU
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
Gaming what games? Some games will see more from GPU upgrade some from CPU upgrade.
current PC:
PC configs I used before:
Just now, Maxiboi69 said:
Could you link the GPU please, I want to be sure I'm looking at the same one, 🙏
? Do you mean give a store for it or smt?
As long as you have an "Rx 7600 XT 16gb" infront of you that is it, no specific models or any of that jazz matters
First custom PC soon(-ish)!
Current part list:
Case: Corsair 4000D (✨WHITE✨)
GPU: Radeon RX 7900 XT
CPU: Ryzen 7 7700
CPU Cooler: Thermalright Peerless Assassin 120 (✨WHITE✨)
Mobo: ASRock B850 Pro RS
RAM: ADATA XPG Lancer Blade 2x16GB 6000MT/s CL30 (✨WHITE✨)
SSD: Lexar NM790 2TB
PSU: BQ Pure Power 12 M 850W
Alright, thanks, how much of an upgrade do you think that is to my current GTX 1660 SUPER?
Depending on the game and resoultion about double your performance
a lot lol, look at the chart i sent
Current part list:
CPU: Ryzen 7 7700
6 minutes ago, AlexithinkSR said:
this got buried as soon as i sent it
Current part list:
CPU: Ryzen 7 7700
Knowing your resolution, power supply and RAM would be a big help to us.
https://www.ceneo.pl/117241141
MSI MPG A650BN 260,00zł
https://www.ceneo.pl/89918234
G.Skill Aegis DDR4-3200 32GB (2x16GB) CL16 228,54zł
https://www.ceneo.pl/Komputery;szukaj-rx+7600+xt
RX 7600 XT
