CPU temps normal ?
Go to solution Solved by Imakuni,
34 minutes ago, ReubsRobbo said:
I have an i9-14900k and a 360mm corsair aio and decided to run cinebench on multi core to test temps . Are these temps alright they seem kinda high but not sure. It’s running at 100% load
specs
i9-14900k
nvidia rtx 4070
1000w nzxt platinum psu
32gb vengeance ram
msi gaming pro z790 a max gaming WiFi motherboard
any help would be appreciated thanks
Yes, it's normal, your CPU does that. Now don't get me wrong, it is bad, but that's what you get for buying a 14900k... if you've done your due diligence and updated the bios, bought the metal bracket to fix the crappy socket, and got a 360mm aio, there's not much more to do at this point.
specs
i9-14900k
nvidia rtx 4070
32gb vengeance ram
https://linustechtips.com/topic/1602641-cpu-temps-normal/
1 minute ago, ReubsRobbo said:
i9-14900k
Do you have all the latest BIOS updates for your motherboard to resolve the voltage issues? That might help temps a bit.
https://linustechtips.com/topic/1602641-cpu-temps-normal/#findComment-16662551
Even if it doesn't solve this issue, it's never a bad idea to keep your BIOS up to date
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1602641-cpu-temps-normal/#findComment-16662554
For 330+ watts I guess it looks ok 😄
Yellow is bedder than red 🙂
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1602641-cpu-temps-normal/#findComment-16662561
specs
i9-14900k
nvidia rtx 4070
32gb vengeance ram
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/1602641-cpu-temps-normal/#findComment-16662571
