2 minutes ago, AustDev said:
Hi
Anyone tried mounting Deepcool AK620 on Asus Z590-E?
The outer RAM will be removed, so ram clearance should be ok, just worried about VRM and Pcie.
The cpu is 11700k so AK620 should be fine if no oc?
Thanks.
Which product line is it?
(TUF, Strix, Prime, etc.)
4 minutes ago, AustDev said:
Hi
Thanks.
Shouldn't be an issue.  The AK620 is actually quite a small cooler.
Absolutely no clearance issues with my ASUS TUF B650 PLUS WIFI and this one has quite tall VRM heatsinks as well.
Thanks, no issue with Pcie too?
And is that enough for 11700K with no over clocking?
2 hours ago, AustDev said:
Dude, it's Strix 🙂
Yeah the lettering moniker is not that obvious for some.
More than enough. And in terms of clearance it should also be fine over pcie.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
