Budget (including currency): $1000
Country: US/Turkey (I live in Turkey but I go back to the US often)
Games, programs or workloads that it will be used for: Fortnite, Minecraft, Cities Skylines 2, and other games that use around the same processing power.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I would like any recommendations on how to make this build better while still fitting in my price range, I know air cooling is cheaper but I like water cooling way more and have had more experience with it. Also I know there is cheaper cases but I want to have room for upgrades in the future. (Please give me recommendations I'm pretty new to PCs)Screenshot2025-02-148_13_37PM.thumb.png.f931b1257174f868360527df9354443c.png
https://linustechtips.com/topic/1601584-building-my-first-pc/
More VRAM
Total: $958.85
PCPartPicker Part List
Motherboard: *Asus PRIME B650-PLUS WIFI ATX AM5 Motherboard  ($124.99 @ Amazon)
Total: $124.99
Generated by PCPartPicker 2025-02-14 12:29 EST-0500
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($184.96 @ Newegg)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($81.97 @ Amazon)
Storage: *Patriot P400 Lite 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($51.99 @ Amazon)
Video Card: *Asus DUAL OC Radeon RX 7600 XT 16 GB Video Card  ($339.99 @ Amazon)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($64.98 @ Newegg)
Power Supply: *Thermaltake Toughpower GF3 TT Premium 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.98 @ Amazon)
Total: $833.86
Generated by PCPartPicker 2025-02-14 12:28 EST-0500
https://linustechtips.com/topic/1601584-building-my-first-pc/#findComment-16655049
