Does anyone know where i can get a fans plus fans rgb controller that will be detected by RGB Fusion from Gigabyte? the one i have at the moment is .. actually no idea what it is it came with the case 1STPLAYER Megaview MV8, Cube Tower, ARGB. but i have no control of synching it with the rest of the lights ... and the fans work at 100% all the time...  can anyone help please? thanks in advance
IMG_20250211_002443.jpg?ex=67abce72&is=67aa7cf2&hm=53d455abef692387a7167798cf191c34f0a6428a5a95b4786485d8d486103099&IMG_20250211_002448.jpg?ex=67abce72&is=67aa7cf2&hm=6c719c2007ace9b4db0046bbf5acfdc042b3923a24540c154b814099f4357457&
https://linustechtips.com/topic/1601067-argb-controller-connector-chip/
You need ARGB or RGB stuff that can be plugged into the motherboard. All that appears to be proprietary stuff that came with the case.  That being said, there appears to be an ARGB connector at the bottom of the board you are holding. That maybe to sync everything with your motherboard (allow you to control it via your applications like you want) Do you have a manual for this case? I did not see one on the website for it? Or what does that board say next to that connector at the bottom (the black connector with 3 pins stick up out of it)?
As for the fans, and 100%, what are they powered by?
