Unraid VM help
Go to solution Solved by manikyath,
the vnc console is a feature of the emulated GPU.
as for expanding VM disk size, according to a forum post on unraid's forum, you do that here:
Hello everyone, i had something happen today I'm hoping someone can help me with. I set up a Windows 11 vm in unraid and had been using it just fine for a while. I then decided to do a GPU passthrough on the VM and once I did the console remote link went away. A picture of that is below. Luckily I had put Teamviewer on the system just in case so I can still remote in but there is a longer delay for imputs. Is there any way to get that back or am I just out of luck?
https://linustechtips.com/topic/1600865-unraid-vm-help/
Thank you, that's very unfortunate that you lose the vnc console. I didn't realize that.
As for the capacity change idk how you found that but I'm glad you did. I googled it no less than 10 times and asked chat gpt another 10 lol
https://linustechtips.com/topic/1600865-unraid-vm-help/#findComment-16650394
i dont know what to tell you.. i googled your question, found someone on unraid forums asking your question, and went to try the answer on my unraid box.
https://linustechtips.com/topic/1600865-unraid-vm-help/#findComment-16650397
