Need help with cable mod
Go to solution Solved by IkeaGnome,
1 minute ago, TurkishBTW said:
yes but am wondering what it means by latch like is it where the gpu clips onto?
No. It's the latch that holds the power connector into the GPU..
Recently I have been wanting to find a 90 degree cable for my gpu. currently I have an asus tuf 4070ti super. While looking through my box for the gpu they offer a cable mod discount. And I was just wondering if anyone could help explain the 90 degree cable options to me. I want to get this cable https://store.cablemod.com/product/cablemod-c-series-pro-modmesh-sleeved-12vhpwr-90-degree-stealthsense-pci-e-cable-for-corsair/ I currently have a corsair 1000e and wasnt too sure if the cable was compatible. Also I dont really understand the two different variants. I read the description but its not clicking. so if anyone could elaborate on it would be very appreciated. BTW as of rn the gpu is vertically mounted if it made a difference with the variants
https://linustechtips.com/topic/1600800-need-help-with-cable-mod/
Essentially its where the GPU notches are on the power connector. This is either at the bottom or top of it. If you got a top notched GPU, Variant A. If you got a bottom notched GPU, Variant B. If you want the cable to run to the top above the backplate, flip the purchase decision, though for 12VHPWR i would run it downward by default to reduce straining. But if you got vertical for most part it wont matter.
Also, right cable. RMe line uses Type 4 cable.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Thank you for the response! Wouldn’t it be variant A because the 12vhpwr connector clips at the top and you said type 4 cable I couldn’t really find where it says that but the one I linked I’m pretty sure your saying is correct IMG_9019.thumb.jpeg.c8d14ce2ad353e59a888c4ef571e0a0d.jpeg
Compatibility – CableMod Global Store
It's all in the product description.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Not the adapter end. The one on the GPU board.
Project Hot Box
Oppbevaring
