Budget: 1300 - 1500€
Country: Germany
Games, programs or workloads that it will be used for: I want to use it for after effects, blender, Premiere, topaz labs, Visual Studio code
For gaming i just play cod and a bit fortnite.
Other details I dont care that much about gaming but it should have at least 144 fps on mid settings in fortnite. For other things i just wanna run after effects smooth.
This is the first pc im building so i dont have any knowledge but i hope im in right hands.
Thanks in advance.
https://linustechtips.com/topic/1600587-building-my-first-pc/
Country: Germany
Games, programs or workloads that it will be used for: I want to use it for after effects, blender, Premiere, Visual Studio code
This is the girst pc im building so i dont have any knowledge but i hope im in right hands.
Thanks in advance.
What is your monitor resolution or do you require a monitor in the budget?
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648473
White theme. Something like this:
PCPartPicker Part List
CPU: AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€153.69 @ Caseking)
CPU Cooler: ARCTIC Freezer 36 A-RGB CPU Cooler  (€36.90 @ Alza)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  (€122.35 @ notebooksbilliger.de)
Memory: Crucial Pro Overclocking 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€89.99 @ Amazon Deutschland)
Storage: Patriot P400 Lite 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€58.90 @ Amazon Deutschland)
Video Card: Sapphire PURE Radeon RX 7800 XT 16 GB Video Card  (€528.87 @ Galaxus)
Case: Montech AIR 100 LITE MicroATX Mid Tower Case  (€50.90 @ Alza)
Power Supply: Gigabyte UD-GM PG5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€89.52 @ Proshop)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fan  (€6.49 @ Alza)
Total: €1150.59
Generated by PCPartPicker 2025-02-07 17:47 CET+0100
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648476
Would likely do something in this range, potentially moving to a 7900 XT/X or 7900 GRE if its within budget.
PCPartPicker Part List: https://de.pcpartpicker.com/list/tvWXJn
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  (€306.19 @ Mindfactory)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€39.90 @ Amazon Deutschland)
Motherboard: Gigabyte B650 EAGLE ATX AM5 Motherboard  (€139.90 @ Alza)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€95.90 @ Amazon Deutschland)
Storage: Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€147.90 @ Amazon Deutschland)
Video Card: ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card  (€498.90 @ Mindfactory)
Case: ADATA XPG VALOR MESH ATX Mid Tower Case  (€46.90 @ Alza)
Power Supply: Enermax REVOLUTION D.F. 2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€79.90 @ Amazon Deutschland)
Total: €1355.49
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648478
Total: €1355.49
Im sorry if im wrong but arent amd cards "bad" for video editing?
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648486
https://geizhals.de/  <--- compare prices here
https://geizhals.de/microsoft-windows-11-home-v87066.html
CPU: *Intel Core i5-14400F 2.5 GHz 10-Core Processor  (€148.90 @ Alza)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  (€39.99 @ Amazon Deutschland)
Motherboard: *MSI PRO B760-P II ATX LGA1700 Motherboard  (€146.99 @ Amazon Deutschland)
Memory: *Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€179.90 @ Alza)
Storage: *Patriot P400 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€104.90 @ Amazon Deutschland)
Video Card: *Asus DUAL EVO OC GeForce RTX 4070 SUPER 12 GB Video Card  (€674.86 @ Galaxus)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (€66.90 @ Alza)
Power Supply: *be quiet! Pure Power 12 750 W 80+ Gold Certified ATX Power Supply  (€96.60 @ Galaxus)
Total: €1459.04
Generated by PCPartPicker 2025-02-07 17:58 CET+0100
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648492
Might not pull the same uplift between chip models, but they still perform entirely fine.
https://www.pugetsystems.com/labs/articles/amd-radeon-rx-7900-xtx-24gb-content-creation-review/
https://linustechtips.com/topic/1600587-building-my-first-pc/#findComment-16648495
