Budget (including currency): $2500 - 3000 AUD
Country: AUSTRALIA
Games, programs or workloads that it will be used for: Rainbow Six Seige, Discord, Arma Reforger, YouTube
Other details: please may you suggest me a monitor with this budget. If you go over budget that’s fine I just want something that will run these games and applications at the same time.
https://linustechtips.com/topic/1600572-new-build-help/
Alright the games aside
What resoluton do you play at?
Anything else productivity related that you will do with the build and if so what?
Do you care about upscalling and RT or just raw performance?
Lastly do you want a specific look and or color such as an all white PC?
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648367
22 minutes ago, joe_ollie909 said:
Budget (including currency): $2500 AUD
Country: AUSTRALIA
Hello
For a mostly competitive FPS build, a bit above budget but I can't see much to shave off, unless you go with a worse monitor
PCPartPicker Part List
CPU: AMD Ryzen 5 9600X 3.9 GHz 6-Core Processor  ($398.00 @ BPC Technology)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($55.00 @ Scorptec)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard  ($288.00 @ Mwave Australia)
Memory: G.Skill Trident Z 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($179.00 @ JW Computers)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($169.00 @ Centre Com)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($729.00 @ Centre Com)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case  ($119.00 @ PCCaseGear)
Power Supply: NZXT C850 (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($177.00 @ I-Tech)
Monitor: Dell Alienware AW2523HF 24.5" 1920 x 1080 360 Hz Monitor  ($580.09 @ Amazon Australia)
Total: $2694.09
Generated by PCPartPicker 2025-02-08 01:15 AEDT+1100
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648370
here's another build it has a better cpu but some of the same stuff as the other build.
https://pcpartpicker.com/list/s7dC4p
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648379
I'd suggest you turn the Website to AU instead of US cause you blew the budget a bit too much out of proportation than needed
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648384
1 hour ago, PDifolco said:
Hello
Total: $2694.09
Hey,
This looks good.
I would rather use NVIDIA, what GPU would you recommend?
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648436
1440p I’d be happy with.
I just want to use the PC for strictly gaming and YouTube.
I would like ray tracing yes. I do like the look of graphics.
would rather a black PC look, not mega fussed on RGB.
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648439
1 hour ago, joe_ollie909 said:
Hey,
This looks good.
Thing is for FPS games AMD cards are better and cheaper, as you won't use neither DLSS nor RT
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648505
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($329.00 @ Centre Com)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($59.00 @ Scorptec)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($259.00 @ MSY Technology)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($146.00 @ MSY Technology)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($164.00 @ MSY Technology)
Video Card: *Gigabyte WINDFORCE MAX OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($1399.00 @ Scorptec)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.00 @ Centre Com)
Monitor: *Asus TUF Gaming VG27AQ1A 27.0" 2560 x 1440 170 Hz Monitor  ($247.00 @ JW Computers)
Total: $2851.00
Generated by PCPartPicker 2025-02-08 04:16 AEDT+1100
https://linustechtips.com/topic/1600572-new-build-help/#findComment-16648513
