20 minutes ago, SolarMan27 said:
Hey there! my mouse randomly stopts working and it doenst work without any usb hub attachted to my laptop if i plug it into my laptop without any connector its not working is there a way to fix this or is it over for this 70 bucks mouse
Do I understand correctly: you're using a Bluetooth mouse with your laptop? And does it "randomly stop working" like "during use" or after some time without you interacting with it?
In any case, the first thing you should do is to see if there's a firmware update for your mouse. Just google your mouse + "firmware update".
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
Try this:
You could check the Control Panel Device Manager Properties Power Management settings for your mouse and whatever usb ports you are using to connect it. You want to make sure that the Power Management option "Allow the computer to turn off this device" is UNchecked.
15 minutes ago, SolarMan27 said:
Logitech G Pro X Superlight
Mice that require dongles typically need good line of sight between the mouse and the dongle.  Any obstruction can cause loss of the signal.
It could also be the laptop itself is emitting interference that reduces the wireless signal quality when plugged into specific USB ports.
