I have a MacBook Pro, using bootcamp to run windows 7 home premium. Yesterday, it started wiggin out on me, and I couldnt do anything, so I did a hard restart. I let it sit for a few hours to cool down but still every time I try to turn it on, I get to the screen where I can choose to go to my Mac or Windows OS, and when I choose one, the screen goes black, flashes once all white for a split second, and then nothing happens. Any thoughts? I could really use some help with this right now
https://linustechtips.com/topic/159995-computer-not-starting/
My best bet is the boot sector/manager is fucked
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2131016
Probably a corrupted HDD or Sector that you install your OS onto
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2131063
Actually it does sound like your hdd is dead, so here is something people don't know about hdd failure rates, my coworker calls it the bathtub failure rate. If you plot failure rates against time (this in a paper done by google) you find that failures happen either in the beginning 6 months or after 5 years not in between. So if you have a harddrive that fails it either fails in the beginning but if you get it past the 6 month point you can expect it to last until the end of its warrenty or after, so sorry dude you just got a bad luck with harddrive.
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2131305
This HDD is less than 6 months old, there's no way it needs work already, I'm careful about viruses and such
Bro bro bro... Dont believe when it needs no work already, if its dead, its his time. dont waste your time trying to recover the HDD and i suggest buying an SSD to boot the OS onto. No matter its <6 Months if its corrupted/dead/bad sector, it remains it is.
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2132990
So I've just finished trying 3 other hard drives in the laptop, as well as putting my Windows 7 is disc in the drive and starting up to that, and still none of it works. I used a sata connector with my hdd on my dad's computer, and it's just fine, nothing wrong with it, so what would be the next thing wrong with the computer not boring properly? I really need to fix this thing as cheap as possible because I was supposed to sell it to my brother but note I can't
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2147554
That is uhhhh, wow I hate to say this to you but it sounds like your intel harddrive controller is probably dead, the symptoms you're bringing up sounds like what would happen if the bios CANNOT find the boot sector on a harddrive, ANY harddrive, I'm not an expert on the hardware in a macbook but you might want to start preparing for the worst. Hopefully you still have the warrenty on it.
https://linustechtips.com/topic/159995-computer-not-starting/#findComment-2156722
