I just assembled a new pc. When i press start it starts the sounds come i have connected it with hdmi from my 750ti.
The display doesnt comeup i even tried it with the mobo hdmi still no display and then i removed the 750ti and tried with cpu i3 4150 still no display. What to do?
https://linustechtips.com/topic/159879-display-not-coming/
Maybe you can try your GPU on some other motherboard to see if it's working. and putting another graphics card into your new system.
Btw what do you mean sound comes when you turn PC on, Is there beeping, fan sound or some other sound?
All the fans start up, hard drives
https://linustechtips.com/topic/159879-display-not-coming/#findComment-2129582
Check that you have 6/8pins plugged into your GPU, check all motherboard connections, CPU Power, 24 pin. If it still doesnt work, if you have 2 sticks of RAM, take one out, run it like that, if it still doesn't work, switch to the other stick, if still no luck, I'd guess you have a RAM/GPU fault.
My video card doesnt need external power, cpu and 24 pins are connected. I will try to do the ram thing
https://linustechtips.com/topic/159879-display-not-coming/#findComment-2129595
run the pc whit out the 750ti first. just of the onbord. if it stil dosent display. plug the power out, remove the cemos battery and wait 30 sec or so  insert the cemos again an start the pc again still whit out the 750ti. it should post now and display  shut down and now start whit your 750ti
https://linustechtips.com/topic/159879-display-not-coming/#findComment-2129807
