I'm going to get together my 1st rig and so I'm not sure about the amount of psu power I will require.
Built:
i5 4670K(not gonna overclock) But still will keep a K model as there is no price difference as to a deal.
or
i7 4770K(I can go for this if I save on psu and other components and somehow increase the budget)so let me know the psu requirements for both processor( I will use only 1 BTW)
Case: NZXT H440 and will use only the fans included (4 fans included) but ya I want few expansion later on.
Mobo: Asus z87-a
ram: 1x8 GB DDR3 Corsair Vengeance DDR3 8GB RAM (CMZ8GX3M1A1600C10)(can't go for an dual channel)
gpu: MSI Twin Frozer GTX 770 2GB GDDR5
SSD 120gb evo samsung
HDD 500gb 5400 rpm segate(I have external storage like 4 tb segate so wont invest money in internal due to tight budget)
optical drive (external dvd writer) not possible due to the casee
Cooler: Corsair H100i(only if I save money)
I have calculated in cooler master's website power supply and they showed that I only need 490W (choose i5 for it though) but I asked few of my friends who have build there rig before and they said if I get 600W then later on it will be problem if I add 1 o 2 more fans or hdd....
SO PLS HELP! LET ME KNOW THE AMOUNT I NEED. DONT WANT TO SPENT TOO MUCH OVER IT THOUGH. I wont overclock and if I in future then I will add a new psu and remove the existing.
https://linustechtips.com/topic/159862-power-supply-requirement/
http://extreme.outervision.com/PSUEngine
460W at 100% (which you will rarely ever reach)
So...get a 550-600W Bronze PSU,just like @DEcobra11 said.
https://linustechtips.com/topic/159862-power-supply-requirement/#findComment-2129443
