I need help please. I do a lot of blueprint reading for job estimates so using a bigger screen like a tv helps but I'm constantly switching the hdmi cord from my monitor to tv depending on what I'm doing. I am looking for a hdmi output selector but in seems like all of them do the opposite by taking multiple inputs to a single monitor. Is there a device out there that does what I am asking for. Thank you.
https://linustechtips.com/topic/1598231-output-switch/
Why not keep them both plugged in and just use software to choose which display you have enabled?
https://linustechtips.com/topic/1598231-output-switch/#findComment-16636291
This seems to be what you're looking for. It can be either 1x2 or 2x1.
https://www.amazon.com/2x1-HDMI-Switch-120hz-OREI/dp/B09SNNBBZ3/
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1598231-output-switch/#findComment-16638748
