Hi,
I'm looking for a cheap fan controller to control 3 case fans (3 pin).
I don't want to spend over £10 ideally.
I need something that can turn down the fans for when I'm sleeping (about 2m from computer) and still keep the computer cool enough at a minimal load (just downloading); then turn up the speed whenever I'm gaming to get decent cooling performance.
P.S. I live in the UK so it has to be available there.
Thanks in advance.
https://linustechtips.com/topic/159802-cheap-fan-controller/
Well, if it's only 3 fans,chances are you can control them by your motherboard bios or other software(speedfan) but here is a cheap fan controller http://www.amazon.co.uk/Akasa-AK-FC-06BKV2-Ports-Speed-Controller/dp/B00B4T2COS/ref=sr_1_1?ie=UTF8&qid=1401537886&sr=8-1&keywords=akasa+fan+controller
Ninja'd
Edited by SpyRosL
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/159802-cheap-fan-controller/#findComment-2128760
