Help upgrading my pc
7 minutes ago, Ash275 said:Budget (including currency): £400-£500 (uk pound)
Country: UK
Games, programs or workloads that it will be used for: I want to use it to mainly run story games such as Yakuza, FF7 remake/rebirth and RE.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I currently have a Gigabyte h310m s2h motherboard, Intel Core i3-8100 CPU @3.60GHz 4 cores processor, NVIDIA GeForce GTX 1060 3GB GPU, 16GB RAM.
Im trying to focus on upgrading the pc to be able to play any of the games stated on medium-high as currently my setup wont even play them on low unless its at 30fps which isnt really appealing. Im looking for Processors and GPU's that i should just be able to upgrade directly without the rest of the system as i dont need anything top range just enough to play most games on medium-high graphics, im not too sure on the compatibility hence why im asking but i like the look of the geforce rtx 3050 or 4060 and the intel i5-12400F, not sure if they would work in my system so looking for info if they would run or if there is anything beter/whats a good upgrade i can do.
Thanks alot,
Ash
A 12400f and a 4060 would be an incredible jump in performance.
You should be able to reuse the RAM but you would need a new motherboard.
You do not mention your power supply though, this is very important. Let us know what PSU you have.
There are definitely cheaper motherboards out there but they are so barebones and they lack features.
