Budget (including currency): 3000 AUD/1900 USD
Country: Australia
Games, programs or workloads that it will be used for: Majority gaming, programming on the side
Other details
CURRENT PARTS:
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor  ($539.00 @ Centre Com)
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX XT 65.57 CFM Liquid CPU Cooler  ($239.00 @ Amazon Australia)
Motherboard: MSI B650M PROJECT ZERO Micro ATX AM5 Motherboard  ($315.00 @ Centre Com)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($219.00 @ PLE Computers)
Video Card: Asus TUF GAMING OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($1369.00 @ Centre Com)
Case: MSI MAG PANO M100R PZ MicroATX Mid Tower Case  ($129.00 @ Centre Com)
Power Supply: Thermaltake Toughpower GF1 (2024) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Total: $2810.00
Storage is missing from the pc parts list, but I have already purchased a 2tb nvme, so that can be ignored
I am currently wanting to get an all white PC build, and IDEALLY would like to go with the rear-facing cable motherboard if possible
I'll be aiming to play games in 1440p and ideally 4k (not sure how feasible it is within this budget), as well as programming.
The rear facing cable motherboard is mainly a nice to have, I like how the case looks and the mobo happens to be white which was a bonus, for 300 AUD
However, I'm not entirely sure if it's actually "worth" going for an all white build... For example, my build is currently missing out on a white GPU, which from a basic glance was going to cost around an extra ~$300
I would appreciate it if the PC ran quiet, and i'm not sure if the corsair AIO has a reputation for being quiet
I'd appreciate any recommendations for if i've prioritised money in a weird way, or if there are ways i can re-arrange some things and splash out more on a gpu and/or CPU
In an ideal world I wouldn't mind moving up to a 4080 super if the budget could be shimmied around
I don't have any real preference on whether or not I use AMD, Nvidia, or Intel for whatever parts, other than the above 4080 super
https://linustechtips.com/topic/1597732-build-finalization-and-advice-please/
PCPartPicker Part List
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($479.00 @ Centre Com)
CPU Cooler: *Deepcool AG620 WH ARGB 67.88 CFM CPU Cooler  ($89.00 @ Centre Com)
Motherboard: *Asus PRIME B650-PLUS ATX AM5 Motherboard  ($313.13 @ Amazon Australia)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($174.69 @ Amazon Australia)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Total: $1144.82
Generated by PCPartPicker 2025-01-23 16:51 AEDT+1100
Total: $1144.82
How do you think a 4080 super would go in something like this?
Few smart cost compression goes far.
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($55.00 @ Scorptec)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  ($188.00 @ Centre Com)
Memory: G.Skill Trident Z5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($169.00 @ JW Computers)
Video Card: NVIDIA Founders Edition GeForce RTX 5080 16 GB Video Card  ($1600.00)
Case: Deepcool MATREXX 55 MESH ADD-RGB 4F ATX Mid Tower Case  ($88.00 @ JW Computers)
Power Supply: NZXT C850 (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($166.00 @ Skycomp Technology)
Total: $2805.00
Generated by PCPartPicker 2025-01-23 16:57 AEDT+1100
5080 should come out next week, as far as i know.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
It would do fine but I would wait for the reviews of the 50XX cards first and those reviews should be coming out any day now.
https://www.dsogaming.com/news/nvidia-has-revealed-the-prices-for-the-rtx-5090-5080-and-5070/
This price is a robbery. It's only marginally better than a regular 4070ti but costs hundreds of $$ more. Edit: checked the au amazon, u mad lads.
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
Total: $2805.00
Do you know how much hassle it might be to build a pc with a regular fan, and then swap it over to the watercooled aio at a later date?
You wont need it unless if its for aesthetics. AM5 in general has a really well behaved thermals and a simple twin tower design like Thermalright Peerless Assassin 120 is more than enough.
And for swaps itll most likely take around 15 minutes to an hour depending on how tightly you made the cable management. Remove the fans to clear for the one thats for the radiator, dismount the cooler and the backplate (dont drop it) and then install as per instructions.
