so I just changed my case and upgraded a liquid cooling(H100i) after I assemble it, it does not turn on, I plugged in the 8 pin, 24 pin , usb 2 connector, and my cpu fan, case fan too (H440 case) , my motherboard seems to flash green light, and my PSU works since it powers the motherboard.
I have a asus p8z68-v pro
              gtx 760
              CX600
              i5 2500K
              H100i
              H440 NZXT case
https://linustechtips.com/topic/159723-my-pc-doesnt-turn-on-help/
There might be a short. Are you sure the motherboard is properly seated on the standoffs? Sometimes cases have preinstalled standoffs that need to be removed for certain boards.
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
I dont know what Standoffs? But there is a screw in the middle of the motherboard that looks like a capacitor not the usually one that let u place the motherboard in place
If I was you an this seems like a pain but I would take it apart. Maybe starting with The gpu and then try turning it on. But honestly I think taking it apart and putting it together using only the necessary things on the Motherboard box and then see if it is turning on. Plus as the other user posted make sure that all standoffs are in the correct places and none extra.
And if you are wondering where to place standoffs this may help you. Remove any extra that are added and place in what ever ones are not where they need to be.
https://www.youtube.com/watch?v=qzeWODR0OYM
CPU Intel I7-4770k - Motherboard MSI G45 Gaming - RAM G.Skill Sniper Series 8GB !866MHz - GPU Sapphire Dual-x R9-270x Crossfire - Case Fractal Design R4 - Storage SSD-120GB Kingston HyperX 3K + HDD-500GB Western Digital Caviar Blue - PSU Corsair CX750 - Display Asus VH236H 23inch - Cooling Corsair H100i - Keyboard Razer Black Widow 2013 - Mouse Razer Death Adder 2013 - Sound Astro A40s - OS Windows 8.1 Pro 64-bit
i tried unplugging the gpu the hhd using only cpu + h100i + psu but it still stays the same, the greenlight on the mobo is lighten and that was it? I also checked the standoff I removed the unnecessary ones already, perhaps it is the cpu fan?
As Smeyer said, take it out of the case, set it up on your motherboard box with just the bare bones, minimum amount of RAM Modules supported by the motherboard, onboard graphics etc and try to boot it first.
Saves a lot of time when you're checking each component out :)
Wait did it have the extra standoffs in when you tried to boot the 1st time? If so you could have damaged it, it is a possibility
i tried and didnt work, prob will take to NCIX and ask for helps
i did , but the h100i is a 3 pin connector
That should not matter. From my understanding the SATA cable is what powers it and the 3pin is just to monitor the speeds. I can't say that 100% though. I hope you get your issue fixed. Good Luck!
