Small fourm issue.
Go to solution Solved by TheSLSAMG,
Don't really see the issue here.
It's Day Theme 2.0. This is why the banner image is gone.
I have a small issue with the forum. Screenshot below. Everything else works fine. I am using a laptop with a 1c/2t i3 and 4 gb ram. Os is Elementary os Luna.
post-33678-0-00599600-1401511882_thumb.p
https://linustechtips.com/topic/159706-small-fourm-issue/
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127552
Oh. Thanks. :)
Why did they remove it?
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127556
Oh. Thanks. :)
Dunno, I would ask whoever designed it. :)
I like it personally.
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127557
Once I look at it I also like it. Thanks again.
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127561
Just so you guys know, you can still access the old Day/Night theme via the Theme menu on the bottom left of the forum page (any page really).
Personally, it's the orange that kills it for me. That's why I use the custom dark theme.
Interestingly, the menus are different. Not sure if that's how it was with the old Day/Night theme, but on Members with Night Theme 2.0, the A-Z sorting is off to the left. Cool. I like that.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127612
You can change it back at the bottom, I did.
Already done. :)
https://linustechtips.com/topic/159706-small-fourm-issue/#findComment-2127666
