Memory Speed Issue
Go to solution Solved by Hinjima,
6 minutes ago, mtamimi said:
My BIOS reports that my memory speed is 6000, and HWINFO 64 reports that the maximum supported memory clock is unlimited, but the current memory clock is only 3000!....is this a problem?
DDR in DDR5 stands for Double Data Rate.  So if its saying 3000Mhz its actually 6000Mhz.  3000Mhz x2 🙂
If you have EXPO or XMP Enabled that is.
Motherboard: ASUS ROG Strix X870-F Gaming WIFICPU: Ryzen 7 9800X3D, GPU: PNY RTX 4080 Super 16GB, Memory: Lexar DDR5 32GB (6000), SSD: Samsung 990 Pro M.2 NVME SSD 4TB, HDD: Seagate 18TB 7200 RPM ,PSU: Egeira 1200W 80 Plus Gold, Cooler: Cooler Master MasterLiquid 360 ATMOS.
https://linustechtips.com/topic/1596795-memory-speed-issue/
https://linustechtips.com/topic/1596795-memory-speed-issue/#findComment-16626453
Thanks...
https://linustechtips.com/topic/1596795-memory-speed-issue/#findComment-16626455
4 minutes ago, mtamimi said:
Thanks...
No Problem 🙂  You are not the first to be confused about this.
If you have XMP or EXPO enabled and it says 3000Mhz,  its actually running at 6000mhz 🙂
On the computer I am using now I run DDR5 5600Mhz.
HwInfo reports 2800Mhz.   2800x2 = 5600.
https://linustechtips.com/topic/1596795-memory-speed-issue/#findComment-16626456
