Hi Everyone,
I have upgraded a laptop to windows 8.1 and now i can't get rid of the windows 8 boot.
Can someone please help.
post-13631-0-89186700-1401496616_thumb.p
Asus Maximus VI Extreme, I7 4770K, NZXT Kraken X60, Kingston HyperXBeast DDR-3 2400, Sapphire 6950, NZXT Phantom 820, SanDisk 120Gb Extreme x2 in Raid, 2Tb WD Green, SeaSonic X-850 Gold
https://linustechtips.com/topic/159637-help-with-win-81/
Do you have a windows.old file in the c: drive?
If you do use this and it will probably get rid
of the boot option. http://windows.microsoft.com/en-us/windows-8/how-remove-windows-old-folder
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/159637-help-with-win-81/#findComment-2126827
In one of the OS, look at System Configuration (msconfig) (Start > type: msconfig), under the Boot tab. You should have the option to remove the other OS.
How did you upgrade to Windows 8.1, by the way?
what this guy said
go to msconfig
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
https://linustechtips.com/topic/159637-help-with-win-81/#findComment-2142567
