High CPU Temp Issue
By
Fetttty
in Troubleshooting
in Troubleshooting
Solved by nano_705,
1 minute ago, Fetttty said:I actually do have a noctua air cooler that I'm considering at this point but I really wanted to fix it if possible. I suppose I could mount the air cooler with the radiator still mounted in the case just to check.
Yes. That's what I'm suggesting you to do, just checking if the AIO cooler is defective or not.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
