11 minutes ago, Cataclysm said:
I wanna know if I should change anything in this build and if it will work
This is a great build in theory but there are a few things I would change.
The NH-D15S is very expensive... Get a Peerless Assassin SE120 instead.
Dont use one 16GB and one 8GB stick of RAM.  And they are different speeds too... No No!
Get either 2x8GB or 2x16GB.  6000Mhz CL30 is the sweet spot.
You can also get a better PSU for the money.
Paying 138 dollars for a windows licence is insane. You can get it cheaper elsewhere.
And 500 bucks for a 3060 Ti is also a no no.
Something like this maybe?
https://pcpartpicker.com/list/t4TPfd
7 minutes ago, Hinjima said:
This is a great build but there are a few things I would change.
Ah thankyou, this was very helpful man. Cant thank you enough
Screen grabs are an absolute PITA, especially on smaller devices.
Post the permalink (link above the build list). Or, use the BB button. (on the toolbar above the list) and post a BB formatted list.
You might also consider reading the first post in
The memory configuration is sub-optimal and may well have stability issues.
The RAM, and overpriced bad PSU. (not bad but you can find better for price)
Overpriced CPU cooler.
Also could get 1TB instead of 512GB drive.
For 500$ you can also get significantly better GPU.
Is there a reason you have white case and everything else black?
Also H9 isn't cheapest case either.
here's an improved list, that stays within your budget:
https://pcpartpicker.com/list/QDgzv4
check out this monitor:
current PC:
PC configs I used before:
Aah thankyou for the advice, I did some editing on the parts but the reason I picked the 3060 is because it's something I already have and will put in
I wasnt focused on color while picking the parts but I'll fix that now, thanks.
I appreciate the attempt, but this is the url of any users build list. I've highlighted the permalink below.
https://pcpartpicker.com/list/WG8jGJ
The CPU cooler overhangs the memory area so the lighting on the memory will be obscured. Consider instead https://pcpartpicker.com/product/cCKscf/silicon-power-value-gaming-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-sp032gxlwu60afdeae.
https://pcpartpicker.com/product/phVmP6/thermaltake-toughpower-gf3-tt-premium-850-w-80-gold-certified-fully-modular-atx-power-supply-ps-tpd-0850fnfagu-4 is a slightly more expensive and slightly better PSU.
https://www.aliexpress.us/item/3256807886761748.html
AMD Ryzen 5 7500F $127.58
PCPartPicker Part List
CPU Cooler: *ARCTIC Freezer 36 A-RGB CPU Cooler  ($33.86 @ Amazon)
Motherboard: *Asus PRIME B650-PLUS WIFI ATX AM5 Motherboard  ($149.99 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($81.99 @ Newegg)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($92.97 @ B&H)
Video Card: *Gigabyte GAMING OC Radeon RX 7700 XT 12 GB Video Card  ($404.99 @ Amazon)
Case: *Phanteks XT PRO ULTRA ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.98 @ Amazon)
Monitor: *MSI G255PF E2 24.5" 1920 x 1080 180 Hz Monitor  ($114.99 @ B&H)
Total: $1028.76
Generated by PCPartPicker 2025-01-09 23:05 EST-0500
