Hello,
Recently I've built a system with an X870 Aours Wifi7 Ice + 9800x3D, the AIO that is cooling it is Lian Li Hydroshift TL LCD
The problem is whenever pc comes from sleep the CPU temperature skyrockets to 96° and then the fans kick off to maximum but it takes about a minute or two for it to drastically drop the temperature to idle 45°.
I've tried plugging the pump into CPU FAN header and CPU OPT, same thing happens, tried reinstalling Connect L3 software, even enabling ErP in the BiOS settings for I don't really know the right reason.
I'm worried the CPU will get damaged if this continues so I've disabled SLEEP but I would rather fix this problem. Please help! Thanks.  🧐
https://linustechtips.com/topic/1595109-pc-sleep-cpu-temps-high/
  • 5 weeks later...
  • 1 month later...
