Problem with Ubuntu Installation
I am trying to install Ubuntu 24.04.1 but am facing an error while booting into the bootable image file. I have made a video to make it easier to understand:
https://www.youtube.com/watch?v=AxKaRQIOVWE
The specific error I am facing is:
[1.879099] 1dm_parse_tocblock(): Cannot find TOCBLOCK, database may be corrupt
This happens during the 'disk setup' part, and I cannot proceed further with the installation.
Any help would be greatly appreciated.
NB: I am a noob at this stuff but curious to install dual boot.
https://linustechtips.com/topic/1594775-ubuntu-installation-error-help/
The error you encounter at first might not be the culprit. There are often always some errors popping up on any type of system, but not all of them are critical, and in your case, it does still boot the live image. Or maybe it is the culprit as the Ubuntu installer program is not able to proceed.
Can you mention how did you make the live image bootable, and all your drive(s) configuration? Did you try recovery mode as well in Ubuntu?
In the live image, do you see all your drives attached? In a terminal, do "lsblk".
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
Quote
i used rufus to make the bootable pendrive
Quote
Quote
no, I did not. In fact I don't know anything about it
Quote
Sorry I didn't understand but if you are saying that if I could see my other drives in ubuntu (on the side panel) then Yes I could see all my drives etc
What did you use to make the bootable USB drive? Might wanna try making a new install on that USB or try another usb drive.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
