Budget (including currency):  £600 MAX
Country: UK
Games, programs or workloads that it will be used for: Rainbow six siege.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  nothing else is needed for the pc just to run rainbow six siege at 100+fps at 1080p
thank you
https://linustechtips.com/topic/1594505-help-please/
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£98.99 @ Amazon UK)
Motherboard: *ASRock B660M Pro RS Micro ATX LGA1700 Motherboard  (£105.82 @ Amazon UK)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£43.98 @ Amazon UK)
Storage: *Patriot Burst Elite 960 GB 2.5" Solid State Drive  (£40.99 @ Amazon UK)
Video Card: *ASRock Challenger D Radeon RX 6600 8 GB Video Card  (£193.99 @ CCL Computers)
Case: *Montech X3 Mesh ATX Mid Tower Case  (£44.99 @ Scan.co.uk)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  (£49.99 @ Amazon UK)
Total: £578.75
Generated by PCPartPicker 2024-12-31 05:19 GMT+0000
https://linustechtips.com/topic/1594505-help-please/#findComment-16610877
Please try to give a more descriptive title than "HELP PLEASE"
Here is a PC that a friend of mine uses. It costs around $530 USD which calculated should cost around £510. But this does not include an OS or any peripherals. However as long as you are okay with buying used components, I would highly recommend looking at local marketplaces to see if you can find any good deals.
https://pcpartpicker.com/list/yMXTYd
Edit: I cannot confirm that this can run R6S at 100+ fps, but I am quite confident it will be able to.
https://linustechtips.com/topic/1594505-help-please/#findComment-16610879
https://uk.pcpartpicker.com/list/brjfyW
5600 + b580 + 32gb 3200c16
not the best value considering the 40£ wasted on the case and the rather subpar psu compared to used (vs rm850x) but if you want the convenience of buying new then this will be half decent value wise just that itll lose by quite alot to a used build
onto the far superior used builds i have two configs depending on if you need more cpu or gpu performance, for the upgrades on both compared to all new they both have far superior rm850x or equivalent psus which you can find for ~50£ used alongside a dual tower frozn a620 cause it doesnt make sense to buy any cheaper coolers unless you are salvaging used 775 or am3 copper coolers which cost basically nothing afaik
https://uk.pcpartpicker.com/list/f6WWt3
8400f + 6700xt + 32gb 6400c32
8400f are 74£ on aliexpress
another benifit being not having to upgrade the mobo nor rams if you wish to upgrade the cpu later down the line
6700xt should be ~200£ used but if you cant find em look for the non xts or maybe even the 3070
https://uk.pcpartpicker.com/list/PYxn6Q
5600(x) + 3080 + 32gb 3200c16
5600 are 58£ on aliexpress but considering the leftover budget i think you can just buy this used locally to save a bunch of time waiting for shipping
used 3080 are usually around the 350£ mark but im pretty sure you can haggle em down alongside find some good deals
used b450 last time i checked uk fb marketplace some went as low as 30£ so might be able to find some <50£ midrangers
do keep in mind that with all of these used builds haggling is a thing and you may be able to knock the prices down some more
heres how the gpus stack up, 3080 = 4070 and b580 has similar perf to 6700xt/4060ti/3070
https://linustechtips.com/topic/1594505-help-please/#findComment-16610925
