I’m working on helping my brother build his first pc and we just can’t seem to figure out where these cables go. The first cable comes out of the case while the second cable comes out of one of the fans. Also the rgb fan control does does not show up in Zeus cast (the case software). Thanks in advance.
note: we are using the stock fans that came with the case
Specs:
Mobo: ASUS prime b550m-a WiFi ii
GPU: Gtx 1060 6gb
Case: Gamdias atlas m1
CPU: Ryzen 5 3600
ram: 32gb hyper x fury
image.thumb.jpg.f47a28fbcd470c41c88ddebd8da1e627.jpgimage.thumb.jpg.b661e329afb49db12e21d2df24bc2290.jpgimage.thumb.jpg.62c774260ce01532b1b883eaac74fcf4.jpgimage.thumb.jpg.4a9b022d9349daaa0b96001a0b31a658.jpg
https://linustechtips.com/topic/1594447-where-does-this-cable-go/
First is for the USB-C connector, your mobo doesn't have a matching port.
2nd if it comes from a fan probably is supposed to go to the fan hub?
F@H
GPD Win 2
2nd seems to be either the power switch or HDD LED one.
Ok thanks, the second one doesn’t seem to be the power switch as the switch is already wired and working and the hdd is labeled and plugged in?
Yeah edited above, hadn't seen it was coming from a fan, so probably goes to fan hub
F@H
GPD Win 2
The page I found says that case comes with a built-in fan hub
F@H
GPD Win 2
